Date/Time: Wed, 12 Feb 2025 12:03:17 +0000
probleme code test CQG
View Count: 452
[2020-10-22 20:16:21] |
User656692 - Posts: 1 |
Hello im probleme my code CQG does not whit sierra |
[2020-10-22 20:25:31] |
John - SC Support - Posts: 37891 |
We are not sure exactly what you are asking. But, if you are having a problem getting connected to CQG, then be sure you follow the Setup Instructions at the following link to connect Sierra Chart to CQG: CQG Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-22 22:28:51] |
Sierra Chart does not support CQG demo accounts: CQG Trading Platform Service: CQG Demo Accounts Not Supported Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
