Date/Time: Wed, 12 Feb 2025 13:51:32 +0000
Global Profit/Loss Management - Enforcement?
View Count: 498
[2020-10-22 08:02:59] |
RolandC - Posts: 54 |
I don't know if you have ever been asked for this, but would it not make sense to add an option to enforce the time delay which is triggered in the event of a certain loss?
[2020-10-23 06:43:13] |
Do you mean so you cannot change or disable this delay? With the way this is implemented, it is possible to disable it for safety reasons in case you have to enter an urgent order. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-23 06:49:42] |
I see. My thinking is no order is urgent once you have reached your daily loss, which you decided when you were thinking clearly. Being able to disable this, kind of defeats the object in so far as it still allows someone who tends to revenge trade to just disable it.
[2020-10-27 09:15:21] |
What do you think?
[2020-10-27 09:41:43] |
This functionality you are looking for is part of our new direct order routing. So this is something that will be available next year.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-27 09:41:53
