Date/Time: Wed, 12 Feb 2025 12:01:26 +0000
Reference Lines from a CSV File
View Count: 1200
[2020-10-21 20:19:20]
User491464 - Posts: 21
I have price reference lines from another charting package that I want to import into Sierra Charts. I can create a CSV file that exports the data from the other software package. Is there a way that I can easily import these levels into Sierra?
Thank you
[2020-10-22 06:09:56]
There really is not an easy/direct way to get the line information into the chart. Although have a look at these two studies:
Horizontal Lines
Trading Levels
Otherwise, you need to build a study to take the data you have and put that into study Subgraphs to draw it as a line (or other format). Refer to the information starting here:
Advanced Custom Study Interface and Language (ACSIL)
Date Time Of Last Edit: 2020-10-22 06:10:35
[2020-10-22 15:52:07]
Ackin - Posts: 1865
Look:
Extending horizontal levels and line levels
