Date/Time: Mon, 25 Nov 2024 12:33:41 +0000
Duplicating All Studies,Defaults,Toolbar Setting to a another Sierra Installation
View Count: 1125
[2014-02-11 20:59:17] |
User13778 - Posts: 24 |
Hi Support I run 2 Sierra Installations. My 'Main' one ( installation 1) is connected to Interactive Brokers using Sierra real Time Data feed. I use this one 80% of the time. I have another Installation ( installation 2) which I use to look at historical data using SC historical Data feed or SC Forex data. I would like to duplicate EVERY setting ( eg Study Modification/Default,Toolbar) etc from Installation 1 to Installation 2 ( essentially everything except the chartbooks of installation 1). What is the easiest way to do this? I have thought about just copying the entire Sierra Folder to a New location and just using installation 2 Chartbooks but think there must be a better way. Thank you to my Kiwi Friends :) |
[2014-02-11 21:35:39] |
This page gives you the information you need: Http://www.sierrachart.com/index.php?l=doc/helpdetails15.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-12 01:48:25] |
Thanks Support for being supportive. Cheers |
