Date/Time: Wed, 12 Feb 2025 12:03:59 +0000
Crash of Sierra Charts
View Count: 431
[2020-10-21 05:23:03] |
User997685 - Posts: 2 |
Hi, Sierra Charts crashed several times today and I do not know what was the issue. would you please check the dump files attached. Thank you for your kind support Hatem |
Attachment Deleted. Attachment Deleted. |
[2020-10-21 05:31:30] |
We want you to update Sierra Chart to the current version. Instructions: Software Download: Fast Update This is a mandatory update. And then run Sierra Chart in Safe Mode: Sierra Chart - Software Login Instructions: Using Safe Mode Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
