Date/Time: Wed, 12 Feb 2025 12:01:59 +0000
New PC build
View Count: 621
[2020-10-21 01:17:12]
User31044 - Posts: 33
As recommended by Sierra Chart, I have the Sierra Chart trading software installed on a separate SSD. I'm building a new Intel PC for trading; can I simply remove my Sierra Chart SSD from my old AMD trading PC and install it on my new Intel PC, or will there be compatibility issues?
[2020-10-21 05:36:03]
Yes this will work perfectly fine. If the drive letter changes, then just make sure this particular setting is correct:
General Settings Window: Data Files Folder (Global Settings >> General Settings >> Paths >> Files and Folder Paths)
