Date/Time: Tue, 04 Nov 2025 18:18:17 +0000
eSignal
View Count: 3600
| [2013-04-18 02:29:26] |
| kona808 - Posts: 12 |
I have downloaded the latest Sierra. I now see eSignal in as a data provider option. I have eSignal On Demand delayed data for some indexes I'd like to chart in Sierra. Is this possible? Connection? thanks |
| [2013-04-18 03:44:34] |
E-Signal is still under development. And there will be a separate subscription for it from E-Signal.
| [2013-04-18 04:52:42] |
Great, thanks. Timeframe? Data only or data and trade?
| [2013-04-18 05:27:04] |
The timeframe to availability is hard to say because it depends upon E-Signal. We are using a less common data feed of theirs. Apparently it is new and it has some issues that need to be resolved by them. They also have not yet established pricing or an order form for the service. It can still be another 30 to 60 days away. Only market data will be supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
