Date/Time: Wed, 12 Feb 2025 16:10:51 +0000
Market Depth Historical Graph Not Updating
View Count: 1077
[2020-10-20 20:06:42]
User643426 - Posts: 127
The Market Depth Historical Graph is not updating properly. There is only one inventory number listed to the far right at each price level when it should be updating continuously. Also, the Inventory below Market price should be not be highlighted Red but should be Highlighted blue to represent buying inventory.
attachmentChartbook2.Cht - Attached On 2020-10-20 20:03:32 UTC - Size: 4.27 KB - 325 views
[2020-10-20 20:33:06]
John - SC Support - Posts: 37893
We are not seeing any issue with your chart. The linked image below shows what we see when we opened your chart:
http://www.sierrachart.com/image.php?Image=1603225894268.png
If you are seeing something different, please attach a screenshot of what you are seeing so we can compare with the Chartbook you provided.
[2020-10-21 00:29:04]
Thank you. I updated to the latest version of Sierra and in the Settings for the Market Depth Historical Graph study I no longer see the field "Graph only quantities greater than or equal to." Is there another field in the Market Depth Historical Graph that allows you to filter inventory displayed based on size?
[2020-10-21 13:52:41]
We just changed the name of that Input to "Lowest Quantity for Coloring". It still works the same way.
[2020-10-21 14:36:45]
Thank you!
[2020-10-22 02:48:34]
If there are any Market Depth Historical Graph updating issues, refer to:
Market Depth Historical Graph: Market Depth Historical Graph Not Displaying
Date Time Of Last Edit: 2020-10-22 02:48:47
[2020-10-29 12:03:54]
I'm not seeing the Bid-Ask Price Study graphed in stair-step fashion across the Market Depth Historical Graph. The Market Depth historical graph study is working correctly. How can I adjust the Bid-Ask Price study so I can the Bid and Ask prices plotted across the entire screen and not just displayed at the far right of the screen? Thank you.
attachmentSupport.Question.Chartbook.Bid.Ask.Price.Study.Cht - Attached On 2020-10-29 11:58:44 UTC - Size: 4.29 KB - 331 views
[2020-10-29 13:33:41]
In the list of Studies you need to move the Bid Ask Price Study down to below the Market Depth Historical Graph. The order they are in on that page is the order in which they are drawn. Refer to the information here:
Chart Studies: Study Display Order
[2020-10-29 22:21:06]
Thank you. I tried that but it's still not showing the Bid Ask price study plotted across the chart.
attachmentMarket.Depth.Historical.Graph.Bid.Ask.Price.Study.Cht - Attached On 2020-10-29 22:18:34 UTC - Size: 4.31 KB - 278 views
[2020-10-30 13:56:31]
The following link is an image of what we see when we open your chartbook. The amount of Market Depth is different just because of when we connected to the data feed, but you can see the Bid Ask lines are visible. We did not make any changes.
http://www.sierrachart.com/image.php?Image=1604066079994.png
Can you please attach an image showing what you see, as you should not be having any problem seeing the lines.
[2020-11-05 20:35:11]
Sorry for the delay. Here is the screenshot of what I see. I believe the bid-ask price study should be plotted across the screen in a stair-step manner. Thank you!
imageESZ20_FUT_CME[M] 1 Min #14 2020-11-05 15_29_06.514.png / V - Attached On 2020-11-05 20:33:11 UTC - Size: 145.7 KB - 223 views
[2020-11-05 22:33:21]
Please hide the Market Depth Historical Graph and take a screenshot. We want to see what the Bid and Ask lines look like without the Market Depth Historical Graph. Refer to the following to hide a study:
Chart Studies: Settings and Inputs Tab >> Hide Study
