Date/Time: Wed, 12 Feb 2025 11:59:45 +0000
Dom Daily P/L
View Count: 743
[2020-10-20 19:32:57]
User260434 - Posts: 14
HI,
I want to hide the daily P/L on the DOM. I followed the help section and in global settings > chart settings I removed the check mark from display daily P/L. After doing this the Daily P/L is still displayed on the DOM.
[2020-10-20 20:10:42]
Actually its the Trade window that is attached to the DOM. I am trying to hide the P/L on the trade window.
[2020-10-20 22:10:42]
The best you can do with this is to hide all of the profit/loss values in the chart and Trade Window by setting this setting to Do Not Display:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html&CAID=default#ProfitLossFormat
[2020-10-20 22:47:01]
OK, I see how that works on a chart or a trade window attached to a chart, but it doesn't work on a trade window attached to a DOM. So, I'm assuming that is what you mean, it doesn't work when associated with a DOM.
Thank you for the reply.
[2020-10-21 05:33:34]
Yes it does. Make sure you change the setting through Chart >> Chart Settings on the Trading DOM.
Date Time Of Last Edit: 2020-10-21 05:33:49
