Date/Time: Wed, 12 Feb 2025 12:02:10 +0000
Connect Question
View Count: 528
[2020-10-20 17:02:44]
User319167 - Posts: 2
Sierra Chart write: trade account not assigned
Wut where typing my account details?
[2020-10-20 18:15:20]
Connect to the data feed with File >> Connect to Data Feed.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2020-10-23 18:16:06]
Vygantas Tamonis - Posts: 1
SC Futures Order Routing/Data | Connecting to the server futurestrading2.sierracharts.com. Port 11098 | 2020-10-23 14:15:18.228
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2020-10-23 14:15:18.244
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-23 14:15:18.244
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-10-23 14:15:18.244
SC Futures Order Routing/Data | Network connection to server complete. | 2020-10-23 14:15:18.351
SC Futures Order Routing/Data | Starting socket receive thread. | 2020-10-23 14:15:18.351
SC Futures Order Routing/Data | Sending encoding request to server: Binary VLS. Compression: none | 2020-10-23 14:15:18.351
SC Futures Order Routing/Data | Setting DTC encoding to Binary VLS | 2020-10-23 14:15:18.655
SC Futures Order Routing/Data | Sending logon request message. | 2020-10-23 14:15:18.655
SC Futures Order Routing/Data | Received logon response. | 2020-10-23 14:15:18.757
SC Futures Order Routing/Data | Server Name: SC DTC Server. | 2020-10-23 14:15:18.757
SC Futures Order Routing/Data | Server protocol version: 8. Client protocol version: 8 | 2020-10-23 14:15:18.757
SC Futures Order Routing/Data | Connection error: Trade account not assigned. | 2020-10-23 14:15:18.757 *
SC Futures Order Routing/Data | Waiting for socket receive thread to end | 2020-10-23 14:15:18.776
DTC Client socket (1) | CloseSocket call. | 2020-10-23 14:15:18.776
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-23 14:15:18.776
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-23 14:15:18.776
SC Futures Order Routing/Data | Disconnected. | 2020-10-23 14:15:18.777
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-23 14:15:18.876
DTC Client socket (1) | Closed. | 2020-10-23 14:15:18.876
[2020-10-23 18:47:44]
There should not be a problem. Can you try connecting again with File >> Connect to Data Feed.
