Date/Time: Wed, 12 Feb 2025 08:59:58 +0000
Keyboard Short Key - Move entry limit order
View Count: 477
[2020-10-20 16:15:33] |
User837393 - Posts: 140 |
Is it possible to move the pending buy or sell (stop or limit) order through keyboard shortkey once its ploted on chart? I'm familiar with : Customize keyboard shortcuts/ Trading Kyboard Shortcut /Target Order Tick up (or down) or /Stop Order Tick up (or down) But this is not working on for situation as such as the attachement. http://www.sierrachart.com/image.php?Image=1603210462506.png Date Time Of Last Edit: 2020-10-20 16:21:32
[2020-10-20 20:02:15] |
This is only supported for Attached Orders.
