Date/Time: Wed, 12 Feb 2025 12:05:54 +0000
Can't set stop order by only click Trading Dom
View Count: 511
[2020-10-20 14:06:21] |
User68392 - Posts: 5 |
As the image in attached files. I can't only click price bar to set stop order on Trading Dom. It will be a Market order after I click buy price higher than current price on Trading Dom. I want it be the stop order after I click buy price higher than current price, not be a Market order. Same happening if I click sell price lower than current price on Trading Dom. Help me please..How to set? Thank you. |
[2020-10-22 02:52:30] |
Make sure the Chart/Trading DOM is configured as you require regarding order types: Global Trade Settings Windows: Chart DOM Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
