Date/Time: Wed, 12 Feb 2025 11:45:00 +0000
EUREXdepth of the market on the DAX30
View Count: 658
[2020-10-20 11:34:12] |
morganfreman - Posts: 4 |
I would like to see the full depth of the market on the DAX30 index (GER30) without any delays. I have an account 5 Advanced. What data should I purchase? Can you send me a step by step instruction because I got lost :) I use Sierra only for monitoring because I invest with my broker on MT4
[2020-10-20 13:44:46] |
John - SC Support - Posts: 37891 |
For the EUREX you would need to use the Sierra Chart Exchange Data Feed. The Setup Instructions start here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions --------------- We see that you have activated the Denali Exchange Data Feed but have not selected any exchanges. If this was by mistake, then be sure you set the Denali Exchange Data Feed to Disabled so you are not charged for the Data Feed service next month. You can do this from this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliExchangeDataFeed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-21 17:59:01] |
yes, I activated Denali Exchange Data Feed to the source by accident, I couldn't understand how to set the data for Dax30. Can you deduct this fee from my account? has it already been charged?
[2020-10-21 18:08:51] |
no wait. To use the full depth of the market in real time on the dax30 index, do I need to disable Denali Exchange Data Feed? and this data is not delayed? I need a full order book for the Dax30
[2020-10-21 18:34:58] |
Sorry, we just realized that you were asking about the DAX30 Index. Unfortunately, we do not have the data for that instrument. You would have to see if you can get it from one of the providers we work with. Refer to the following list: Supported Data and Trading Services: Supported Services As to the Denali Exchange Data Feed, you just need to go to the following page and set the service to Disabled: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliExchangeDataFeed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-21 19:34:01] |
Hmm but I do not understand this because in the first message you recommended buying data for the Eurex market, which I have already bought screenshot below |
![]() Attachment Deleted. |
[2020-10-21 20:19:55] |
We are sorry, we made a mistake, as we thought you were just looking for the DAX Futures. We did not look closely enough to see that you specified the DAX30. If you do not want the EUREX exchange, then we will refund the $10.00 that you paid for the data feed for the remainder of October. The exchange itself was free for the remainder of this month. Just let us know what you want to do. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-22 08:05:39] |
Instead have a look at using the symbol GER30 through the Sierra Chart Forex/CFD data feed: Sierra Chart Real Time and Historical Forex and CFD Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-22 08:05:45
