Date/Time: Sun, 04 Oct 2026 13:22:49 +0000
[Programming Help] - How to count bars after certain conditions met
View Count: 1104
[2020-10-19 21:10:19]
Luigi - Posts: 18
I am a newbie in SC ACSIL programming, so forgive me if it is a trivial question.
What I try to achieve:
Count n number of bars after certain indicator changed value and change bar color of nth bar.
Problem:
My data processing logic works when chart is loaded first time, but when live or replaying the function called at each price updates and my counter is not counting bars anymore, but the updates on the last bar.
What would be the best way to solve this?
Code snipet which works when chart is loaded:
  int& upCounter = sc.GetPersistentInt(1);
  int& downCounter = sc.GetPersistentInt(2);
  if ((Subgraph_Avg[sc.Index] - Subgraph_Avg[sc.Index-1]) >= 0 )
    Subgraph_TTF_Trend[sc.Index] = 1;
    upCounter = upCounter +1;
    downCounter=0;
  else
    Subgraph_TTF_Trend[sc.Index] = -1;
    downCounter = downCounter +1;
    upCounter=0;
Date Time Of Last Edit: 2020-10-19 21:13:16
[2020-10-20 07:24:24]
User907968 - Posts: 884
You could incorporate this function (ACSIL Interface Members - Functions: sc.GetBarHasClosedStatus()) into your code and only update the count when the bar is closed.
[2020-10-20 11:09:08]
Luigi - Posts: 18
It worked like a charm. Need to digest the documentation more....
Thanks!
