Date/Time: Wed, 12 Feb 2025 08:58:40 +0000
Font color of highlighted lines in Time and Sales
View Count: 442
[2020-10-19 19:42:57] |
User893396 - Posts: 40 |
Hello, Is it possible to change the color of the font of highlighted T&S ? Because I usually look at the T&S with peripheral vision, I'd like to display: - Non-highlighted: Blue(or green)/Red font over a dark background - Highlighted: White font over a Blue(or green)/Red background Currently I am forced to use fancy highlighting colors that make my T&S ugly and not easy to read if I still want to be able to distinguish the font from the background and read the numbers. Would you consider adding this feature if it's not already there? Thank you |
[2020-10-20 11:41:18] |
Yes we will look into this.
