Date/Time: Sun, 20 Sep 2026 14:22:03 +0000
[User Discussion] - Spreadsheet trading: inconsistent execution.
View Count: 727
[2020-10-19 16:08:01]
User484096 - Posts: 20
I have the below exit conditions in the spreadsheet. It is a simple trailing by 2 bars after the entry bar is closed. But about half of the time, the trade is closed as soon as the entry bar is closed.
Today is an example. My entry was executed on 9:30 bar, but as soon as the 9:30 bar is closed, the trade is closed.
Buy Stop
=AND(AND(AND($J$8 > 0, A3 > J42), J41 > A3),(E3 < MIN(D4, D5)))
Sell Stop
=AND(AND(AND($J$8 < 0, A3 > J42), J41 > A3),(E3 > MAX(C4, C5)))
I am using version 2175.
imageNQ.png / V - Attached On 2020-10-19 16:05:12 UTC - Size: 21.19 KB - 351 views
imageStudy.png / V - Attached On 2020-10-19 16:07:33 UTC - Size: 35.41 KB - 352 views
[2020-10-19 18:48:42]
Sawtooth - Posts: 4354
Just like J8, you need to use absolute references to cells J41 and J42:
Buy Stop
=AND(AND(AND($J$8 > 0, A3 > $J$42), $J$41 > A3),(E3 < MIN(D4, D5)))
Sell Stop
=AND(AND(AND($J$8 < 0, A3 > $J$42), $J$41 > A3),(E3 > MAX(C4, C5)))
