Date/Time: Wed, 12 Feb 2025 09:46:28 +0000
Study Settings How To Question
View Count: 521
[2020-10-19 13:00:02] |
User192201 - Posts: 19 |
Hello, I was wondering if we Study Settings - for example - lets take the Subgraphs tabs - There is Short name which is used to identify the study line/area on the chart. Is there way to provide a date to automatically - So, I would like to say for eg Short name {DATE} VPOC and for all the VPOC there will 2020-10-19 VPOC and 2020-10-16 VPOC etc. if not there is there any other way to get a Date on those studies to identify which day we are talking Thank you |
[2020-10-19 17:42:22] |
John - SC Support - Posts: 37891 |
If you are asking for this to be done so you can have a different date showing for a single Subgraph, then this is not supported. Each Subgraph only has a single Short Name associated with it. We are not sure how you want to present the particular data, so we don't really know where to point you to. The only thing we can think of, offhand, is to use the Text drawing tools to denote what you are looking for on the chart where you want it. Refer to the following: Chart Drawing Tools: Type Text | Stationary Text For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
