Date/Time: Wed, 12 Feb 2025 10:09:12 +0000
ES Chart Discrepancies
View Count: 488
[2020-10-19 12:01:45] |
AndreGMS - Posts: 1 |
Hi there, so I left the first attached chart to run overnight and then created the second one just this morning. They are not the same as you can see the second chart is literally missing entire bars. Even duplicating the chart will yield different indicator values... Not sure how to fix this from everything I've read online.
[2020-10-19 13:55:18] |
Range charts will not be the same unless they are starting at the exact same time. We want you to reload both charts with Edit >> Reload and Recalculate. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
