Date/Time: Wed, 12 Feb 2025 10:14:10 +0000
Indicator ADX with Di + and Di - difference between tradingview chart
View Count: 877
[2020-10-17 14:06:31] |
The_last_call - Posts: 8 |
Dear Sierra Chart support Team, I have created my entry method based on specific crossing form Di+ and Di- compaired with a raising ADX line. Until now I have used the tradingview chart for my signals. Now I like to creat an automatik system for this. But when I add the ADX and Directional Movement indicators they akt very differnt compaired to the tradingview chart. On Tradingview I use ADX and DM with period 14, if I do the same on your software the lines are compaired to the tradingviwe lines. What can I do the get the same curves like in tradingview on your software? Thanke you! Date Time Of Last Edit: 2020-10-17 14:08:19
[2020-10-18 10:53:20] |
This question is not within the scope of our support. You can find all of the mathematical formulas here: Technical Studies Reference And you can modify the study to meet your requirements: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
