Date/Time: Sun, 04 Oct 2026 03:05:49 +0000
[Programming Help] - Study Subgraph text above and below
View Count: 1734
| [2020-10-17 13:39:32] |
| User202416 - Posts: 37 |
Hi I am using study Subgraph above and below to plot text either above or below the candle or bar or number bar . I need to plot the text either at last traded price , or middle of the bar or one text above the bid or other text above ask prices in number bar . I think SC is capable of outputting in any areas . Please help me |
| [2020-10-17 18:18:41] |
| Sawtooth - Posts: 4355 |
That study can only plot values at Top Of Bar or Bottom Of Bar. There is no workaround to plot a value at a custom price. It would require a custom ACSIL study. Try this workaround to plot the Last price at the Last price: -Add the Spreadsheet Formula study, -Use a formula like this in the Formula field: =ID0.SG4 -Set the Draw Style to Value of Subgraph. With this workaround you could plot any value at its Y value. |
| [2020-10-19 04:56:49] |
Thanks for your prompt response . If I put IDO.SG4 , only last traded price is displayed . If I reference the study Subgraph text above below study and put that ID.. SG4 , nothing is displayed
| [2020-10-19 13:20:27] |
You can only do these two things with native studies: - Display any value at the bar's high or low using the Study Subgraph Above/Below study. - Display any value only at its Y coordinate using the Spreadsheet Formula study workaround in post#2. Displaying values at a bar's other Y coordinates will require a custom ACSIL study. |
