Date/Time: Mon, 25 Nov 2024 12:44:02 +0000
AMP/TTNet order routing
View Count: 1190
[2014-02-11 15:56:42] |
User77842 - Posts: 1 |
what causes this error: Trade Order Error - TT order update (Rejected). Info: Order routable on multiple gateways. Exchange gateway must be provided. Internal Order ID: 5131. Service Order ID: (none). Symbol: 6E-201403-CME | 2014-02-11 15:52:03 |
[2014-02-11 16:14:10] |
You need to contact your broker about this and let them know you are getting this message: Trade Order Error - TT order update (Rejected). Info: Order routable on multiple gateways. Exchange gateway must be provided Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
