Date/Time: Wed, 12 Feb 2025 10:11:59 +0000
Drawing a rectangle in real time, x ticks up the current price, y ticks below the current
View Count: 520
[2020-10-17 11:04:48] |
User275592 - Posts: 97 |
Hi, is it possible, without programming in acsil, to draw a rectangle in real time, with x ticks up the current price and y ticks below, as the file attached thank you very much for your help |
aide à l'entrée.png / V - Attached On 2020-10-17 11:04:06 UTC - Size: 2.73 KB - 191 views |
[2020-10-18 10:54:57] |
No you definitely do have to use ACSIL: Using Drawing Tools From an Advanced Custom Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-18 11:48:07] |
User48838 - Posts: 121 |
I dont know if something like this would work for you or not but this uses a Spreadsheet Study and the X, Y and Z lengths are manually entered by the user. The Transparency is also controlled by the user. I can post the chart and spreadsheet if it meets your needs. |
2020-10-18_7-44-56.png / V - Attached On 2020-10-18 11:45:56 UTC - Size: 8.47 KB - 205 views |
[2020-10-18 13:53:11] |
thank you . There is a solution in acsil and via spreadsheet. User48838 could you publish the chart and spreadsheet thank you very much !
[2020-10-18 16:37:33] |
Enjoy!
Attachment Deleted. XupYdown.Cht - Attached On 2020-10-18 16:37:00 UTC - Size: 3.87 KB - 389 views DefaultSpreadsheetStudy.scss - Attached On 2020-10-18 16:37:08 UTC - Size: 6.31 MB - 267 views |
