Date/Time: Thu, 25 Jun 2026 12:12:34 +0000
Volume at Price Threshold Alert V2 (Draw Extension lines with Transparent Range)
View Count: 1006
| [2020-10-17 01:52:32] |
| User847553 - Posts: 18 |
hi, I found that some extension lines are not extended, while some are. (see attached screenshot, green circle) The setting for the study can be found in the screenshot as well. how to fix it, please? |
| [2020-10-23 04:24:22] |
hello, can anyone please help?
| [2020-10-23 14:04:08] |
| John - SC Support - Posts: 46877 |
There is not enough information in the image for us to determine what is happening. Please attach a Chartbook with just that one chart in it to this thread for us to take a look at it. Refer to the following instructions for how to post a chart: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
