Date/Time: Sun, 24 Nov 2024 20:27:53 +0000
OpenGL checkbox not staying checked
View Count: 1122
[2020-10-16 23:03:09] |
owendonk - Posts: 54 |
I go to Global Graphics Settings / Other and check the enable OpenGL box then apply. It says I need to restart Sierra Chart and I do. Then I go back to same menu to check and OpenGL is unchecked again. Happens every time. Any ideas? Edit: version 2182 64 bit, windows 10 in parallels on 2020 macbook pro with Intel Iris Plus Graphics 1536 MB Date Time Of Last Edit: 2020-10-16 23:22:05
[2020-10-17 06:07:49] |
This means that OpenGL is not supported on your system. The necessary drivers for it may not be present.
[2023-10-02 15:38:36] |
methodtrades - Posts: 46 |
Sorry to resurrect an old thread, however, it may be helpful for future users encountering this same issue. I was facing this as well. I fixed it by running Sierra (in my case the ARM version) via Parallels, as administrator. It successfully located the OpenGL 4.1 drivers Parallel uses I assume since the checkbox will now stay checked when running in this mode. |
[2024-04-27 15:11:37] |
User130696 - Posts: 88 |
Thank you. On the above lines, there is SierraChart_ARM64.exe, which fixed the issue by running as an admin (windows asks for permission in a prompt) for me but not the default shortcut SierraChart_64.exe that comes with the installation. Anyways the issue is resolved, thanks.
