Date/Time: Tue, 04 Nov 2025 18:18:11 +0000
custom analysis not propigating to all charts
View Count: 2234
| [2013-04-17 23:21:02] |
| hairyMug - Posts: 31 |
I have a custom analysis saved in a "Study collection" called "myStudy" and I have the charts setup so It opens the "myStudy" study collection as the default. This worked fine for the first time the chart was opened BUT when the custom analysis DLL is changed, and the "study collection" "save all" button is used, it does not re-apply the the study to all the charts. I have to go to each chart and click on the "myStudy" under the anaysis menu to apply it. I would expect the "save all" button to apply it across all the charts in the chart book. Is there another way to re-apply a "sutdy collection" to all the charts in a chart book? TIA, Walt |
| [2013-04-17 23:30:29] |
The behavior you see is how it works. You have to do just what you have been doing.
