Date/Time: Wed, 12 Feb 2025 09:36:21 +0000
Live Data
View Count: 401
[2020-10-16 18:11:19] |
User643662 - Posts: 4 |
Hi, I have been trading with TradeStation for the last 2 years and have just opened an account with Sierra Chart. I have live data on TradeStation, so I would like to know how to use that same feed on Sierra Chart, so that I don't have to needlessly pay for the same service twice. Thank you! Roger |
[2020-10-17 00:10:38] |
This is not supported and we really do not know why you would expect that to work. What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Be sure to read the page linked above completely before making a further inquiry regarding real-time *futures* data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
