Date/Time: Mon, 25 Nov 2024 12:19:42 +0000
fast and slow CCI
View Count: 1324
[2014-02-11 15:01:48] |
User37941 - Posts: 10 |
Hi, I have just started using the CCI. A trade room that I am in uses an 8 period CCI and a slower 8 period CCI average cross to indicate a reversal. Is it possible for me to have two CCI lines together? How would I do this? Thanks in advance. Joe |
[2014-02-11 15:42:16] |
Sierra Chart - Max - Posts: 5730 |
You can set studies to share the same Chart Region, for more information please see: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#ChartRegion Sierra Chart Support Date Time Of Last Edit: 2014-02-11 15:44:07
[2014-02-11 17:29:21] |
You also need to base the Moving Average-Simple study on the CCI. This is documented here: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#BasedOn There is also an example of this on the Additional Files page: http://www.sierrachart.com/index.php?l=doc/AdditionalFiles.php The name of the file is CCI_with_Avg.StdyCollct. As is explained on that page you will need to save that file to the Data Files Folder. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-11 17:29:55
