Date/Time: Tue, 29 Sep 2026 18:09:30 +0000
Quantity In-Chart Trading
View Count: 678
[2020-10-16 14:20:57]
User471027 - Posts: 19
In the previous versions it was possible to adjust the lots directly in the chart at the "order line".
With the latest update it is apparently not possible to adjust the quantity directly. Instead, a pop up window opens ("Quantity And Price")where the quantity can be entered.
Is there a way to keep it the old way and making it possible to change the quantity directly at the "order-line"
Thank you.
Private File
Private File
