Date/Time: Wed, 12 Feb 2025 09:49:07 +0000
adding another tab to a chartbook
View Count: 1186
[2020-10-16 13:07:05]
User313147 - Posts: 48
Does anybody know how to add a new tab to a chartbook? I cant see it in the documents.
I want to have the footprint in a tab next to VWAP etc.
[2020-10-16 14:46:35]
John - SC Support - Posts: 37891
If you are talking about the tabs at the bottom (by default) those are your chart tabs. You just need to open another chart for a symbol to add another chart. You can also duplicate the existing chart. Refer to the information here:
Chartbooks (Workspaces): To Add a New Chart To a Chartbook
and here:
Using Chart Templates: Duplicating Charts / Template Charts
If you are referring to the tabs at the top (by default) then those are your Chartbook tabs. Refer to the following for how to open a Chartbook:
Chartbooks (Workspaces): To Create a New Chartbook
[2020-10-16 15:07:25]
I've got footprint on a separate chart and want to have it as a tab at the bottom of another chart that I have open that has VWAP and profile at the bottom, so they are all in one chart and I can move between them all without having to leave the chart.
I can't see how to do that within the links you sent me.
[2020-10-16 15:26:27]
We are not fully understanding what you are looking to do. In general, you cannot have the Numbers Bars and the Volume by Price studies in different regions. They are both setup such that they need to be on the Main Price Graph.
You can have studies like the VWAP in a separate region. Refer to the information here:
Chart Studies: Settings and Inputs Tab >> Chart Region
