Date/Time: Wed, 12 Feb 2025 09:48:49 +0000
How to setup Interactive broker with your data feed.
View Count: 432
[2020-10-16 13:01:02] |
GravisHTG - Posts: 306 |
I would like to try this solution for US stock , i Already check and i would take the All us stock option for around 10$ plus your fee. Another question is that do i need to take package 5 because i only take that for the intraday chart for IB. But if I use your data feed , i think i can skip that. Thanks in advance. |
[2020-10-16 14:20:16] |
John - SC Support - Posts: 37891 |
You have your information correct. If you use our data feed, then you do not need to have Package 5 in order to get the historical data for IB. To connect Sierra Chart to Interactive Brokers for trading, refer to the information here: Interactive Brokers Trading Service: Setup Instructions To setup the Sierra Chart Exchange Data Feed for the U.S. Equities, refer to the Setup Instructions here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
