Date/Time: Wed, 12 Feb 2025 09:53:32 +0000
Auto Scale
View Count: 1085
[2020-10-16 12:13:41] |
Dazz - Posts: 12 |
When I'm Navigating a chart with the "hand" tool the chart is automatically zooming in and out to display the candles on the screen. How do I prevent this. I want the zoom in/out manual only. Thank you.
[2020-10-16 14:16:23] |
John - SC Support - Posts: 37891 |
We assume that you are referring to the changes due to Automatic scaling while you are scrolling through the data. This is not specifically related to the "Hand" tool, it is caused by trying to keep the bars that are in view on the screen when the scaling is set to Automatic. Refer to the following information for how to set the Scaling to not adjust as you scroll through the bars: Chart Scale and Scale Adjusting: Using Fixed Values for Top and Bottom of Scale Range For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
