Date/Time: Mon, 25 Nov 2024 12:44:05 +0000
Silver in IB
View Count: 1069
[2014-02-11 14:24:36]
mayerrs - Posts: 70
hi, i have problem with silver in interactive brokers. i use SI-201403-NYMEX-USD-5000 (as you recommended me last time) but there is some problem. the price is changing, it is ok, but the bars are not drawing.
thanks for your help
ps: the same problem i can see in ZS-201403-ECBOT
Date Time Of Last Edit: 2014-02-11 14:33:43
[2014-02-11 16:15:03]
Refer to help topic 3:
Http://www.sierrachart.com/index.php?l=doc/helpdetails3.html
[2014-02-11 16:30:54]
mayerrs - Posts: 70
i am not able to find out what is wrong but if i use (and i use it) record true real-time intraday data it does not work wor symbols SI and ZS. if i do not use record true real-time intraday data the chart is updating correctly.
[2014-02-11 16:39:11]
Therefore, we recommend disabling Global Settings >> Data/Trade Service Settings >> More IB Settings >>Record True Real-Time Data in Intraday Charts. After disabling this option select File >> Disconnect and then Connect to Data Feed.
You may also be interested in the Sierra Chart Futures data feed:
http://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php
