Date/Time: Wed, 12 Feb 2025 10:17:49 +0000
NQ DATA ISSUES WITH DENALI
View Count: 453
[2020-10-15 23:44:51] |
User28317 - Posts: 149 |
I HAVE HAD A FEW PROBLEMS WITH THE NQ DATA. The chart changes bars before the 15 minutes is up, instead of advancing to the next bar at the conclusion of the chart timer. The immediate issue was that I set the target 25 ticks above the price as a limit order and it filled after a minute but opened down 6.75 points. The price was no where near my order. Can you audit the trade fill? I used the same with YM and had no issues, just the NQ. |
[2020-10-16 01:54:19] |
For CME NQ data you need to activate the CME exchange here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed At this time you are only receiving delayed data. This is why you see what you do. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
