Date/Time: Wed, 12 Feb 2025 09:42:29 +0000
Request for Volume Above/Below TPO POC
View Count: 553
[2020-10-15 17:06:19] |
ForgivingComputers.com - Posts: 1001 |
In version 2182 the Chart Values Window shows a value for TPO Profile called "Volume Above/Below TPO POC". I would like to read that value with sc.GetStudyProfileInformation. Unless I am missing something, there is no method for that. Can that be added? Thanks! Refer to:
sc.GetStudyProfileInformation Date Time Of Last Edit: 2020-10-15 17:06:47
[2020-10-15 19:05:58] |
Yes we can add those variables to the associated data structure.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-15 19:06:25
[2020-10-19 15:18:54] |
Version 2183 is working as requested. Thank you Sierra Engineering!
