Date/Time: Wed, 12 Feb 2025 09:55:02 +0000
Ultra 10 year Notes symbol not located
View Count: 455
[2020-10-15 16:22:28] |
User525965 - Posts: 153 |
Hello- I'm trying to pull up a chart for Ultra notes (symbol TN I believe) and its not showing anywhere under available markets CBOT exchange. I'm using TT data on a simulated tryout account. Is the symbol not available through TT or is there a way I can add it? |
[2020-10-15 16:42:48] |
John - SC Support - Posts: 37891 |
Update your Symbol Settings then it should be in your list. Follow these instructions to update your Symbol Settings: Global Symbol Settings: Update Symbol Settings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-15 19:46:12] |
We have to set up that symbol for the trading evaluator service. It is currently not available. We will do this.
[2020-10-15 20:10:23] |
We have now added this symbol. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
