Date/Time: Wed, 12 Feb 2025 09:54:49 +0000
Sierra Chart Trial / Teletrader
View Count: 537
[2020-10-15 15:59:11] |
User743112 - Posts: 2 |
Hello, I have just created a Sierra Chart Demo and tried to connect it to TeleTrader. I already have a TeleTrader data service with login data. Unfortunately I can't find TeleTrader in the Global Settings - Data/trade Service Settings. I hope you can help me. Best Regards |
[2020-10-15 19:25:52] |
Teletrader is ending support for Sierra Chart in February 2021 but we already removed support for it in newer versions. You need to use an older version of Sierra Chart. Instructions: Software Download: Software Rollback Procedure Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-10-16 05:43:13] |
Hello, that is sad to hear. Are you already planning an alternative for e.g. German stock exchanges ? Unfortunately I would also need prices from German OTC exchanges like Tradegate or Lang & Schwarz, so the main exchanges would not be enough. Best Regards |
[2020-10-16 09:13:57] |
No there are no plans for those exchanges. There just is not enough interest in these exchanges.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-16 09:37:31
