Date/Time: Wed, 12 Feb 2025 10:06:11 +0000
activation account
View Count: 459
[2020-10-15 15:53:40] |
DIFFALAH Khaled - Posts: 1 |
Hi, I have done the payement for using symbols and Eurex and I can not use those. Can you help me please |
[2020-10-15 16:14:13] |
John - SC Support - Posts: 37891 |
We need to understand exactly what the issue is that you are having. In particular, have you opened File >> Find Symbol and opened a EUREX symbol from that list? What do you see when you do this?
[2020-10-15 19:49:04] |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
