Date/Time: Wed, 12 Feb 2025 09:57:44 +0000
[User Discussion] - Customise Flexi Renko Inverse Set
View Count: 897
[2020-10-15 13:13:07] |
batman_ - Posts: 190 |
Can programmer customise Flexi Renko Inverse Set (Bar size-TrendbarOffset-ReversalBarTrigger) to time interval period of minutes and seconds? The current default setting is limited to range price bar. tQ |
[2020-10-17 15:04:15] |
ForgivingComputers.com - Posts: 1001 |
The current default setting is limited to range price bar. Not sure how that would work. What do the bar size, offset, and trigger parameters do? Flex-Renko is based on Renko bars, which by definition are range bars, not time bars. |
[2020-10-17 22:45:54] |
Hi, bradh customise the bar size to time interval, say 3 minutes each bar; offset by 3 minutes too; trigger parameters say 3 minutes subject too, however subject to similar range bar setting of trigger parameters. Can this be done? |
[2020-10-18 10:33:57] |
Based on your description, I don't think so. It does not make sense to me. I am having a hard time visualizing it.
[2020-10-18 12:25:39] |
Sawtooth - Posts: 4173 |
Do you want to create a new bar when range is met, or when 3 minutes lapses, which ever comes first?
[2020-10-18 12:41:36] |
Hi tomgilb Allow me to rephrase my question. I would like to customise Flexi Time Inverse based on minutes or seconds to replace Flexi Renko Inverse. For example, completion of 3 minutes interval represents 1 bar interval, and trigger parameter for reversal trend is 6 minutes. So it takes 2 bars of each 3 minutes interval to complete moving in an opposite trend before a new begining of a reserval trend. Does it makes sense.. |
