Date/Time: Wed, 12 Feb 2025 10:02:04 +0000
Swap volume profiles locations
View Count: 424
[2020-10-14 19:48:13]
User97684 - Posts: 136
Pls is there a way to swap the 2 profiles around - both have the option
'align to far right ' switched to 'No' and both allow profiles side by side.
Many thanks
imageswap volume profiles around.png / V - Attached On 2020-10-14 19:48:03 UTC - Size: 236.97 KB - 172 views
[2020-10-14 21:51:15]
John - SC Support - Posts: 37891
You just need to change the order in which they are listed in the Studies window. Refer to the Move Up/Move Down in following section:
Chart Studies: Chart Studies Window
