Date/Time: Wed, 12 Feb 2025 10:14:34 +0000
Amp same software as stand alone?
View Count: 466
[2020-10-14 18:29:30] |
Tonkadad - Posts: 235 |
My Son has Amp for a broker, can I send him my SC directory and will he have the exact same settings, etc... that I do? I want him to see the same charts/studies that I do. I use IB with Denali data feed. |
[2020-10-14 19:28:38] |
Yes will be fine. Refer to: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation And refer to this command here: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
