Date/Time: Tue, 23 Jun 2026 14:25:21 +0000
Historical market depth bid and ask size
View Count: 881
[2020-10-14 17:15:31]
User589122 - Posts: 7
This is my first suppport ticket. In the attached chart there is a difference between the bid and ask sizes of the market depth in the dom versus the bid and ask sizes in the historical market depth chart. I have no idea where the difference comes from and I hope you can help me with this.
http://www.sierrachart.com/image.php?Image=1602695535800.png
Thanks in advance!
[2020-10-14 18:20:23]
John - SC Support - Posts: 46831
You need to have the Input for Depth Quantity Type to Display After Last Bar set to Last Depth in order for those two sets of data to match up. Refer to the information here:
Market Depth Historical Graph: Depth Quantity Type to Display After Last Bar
[2020-10-14 18:40:20]
Hi John,
Thanks for the quick reply. I checked my settings but the depth quantity type to display after last bar was already set to last depth.
[2020-10-14 19:59:57]
The problem is, you are comparing market depth between two different symbols because you are using this setting:
Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu)
Date Time Of Last Edit: 2020-10-14 20:00:05
[2020-10-15 06:22:31]
Thanks! That worked!
