Date/Time: Wed, 12 Feb 2025 09:35:13 +0000
More Information cause I change from ATAS
View Count: 920
[2020-10-14 15:48:15] |
User158085 - Posts: 4 |
Hello, First, my English is out of praxis, sorry. My account User158085 Now I have activated my account for 3 month. At this time I should use the Denali Exchange Data Feed. It may be optional. I have an account with AMP with real money. I like to use it. Is this enough and how can I use / connect this account ? I’m changing from ATAS to SierraChart. |
[2020-10-14 18:12:09] |
John - SC Support - Posts: 37891 |
The first thing we need to know is who is the trading provider that you have been setup with through AMP? This will be either CQG or the Sierra Chart Order Routing Service. Ask AMP for this information if you do not know. Once we have that, then we can direct you on how to connect. The Denali Exchange Data Feed is optional. You can get data through the trading provider which AMP has setup for you. If you do want to get your data from us, then after we get you setup with your Trading provider, you will then go through the Setup Instructions for the Denali Exchange Data Feed here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-14 19:20:51
