Date/Time: Wed, 12 Feb 2025 10:00:04 +0000
Simple Moving Average for Time Range
View Count: 697
[2020-10-14 13:05:32] |
Profile Trader - Posts: 177 |
Looking for a way to have a SMA on a RTH and Overnight chart with the SMA only using the RTH data to calculate. Right now I am doing this via a separate chart and then overlay. But was hoping that one of the SMA studies allowed this type of configuration. I looked at the Time Period one but if I understand it correctly that will not work for what I am trying to do. Anyone else have a way of doing this vs the two chart overlay method? SC would it be possible to add the option of picking a time period on a 24 hour session chart to calculate a SMA? Thanks in advance for any insight you might be able to share Doug |
[2020-10-15 04:59:57] |
The only standard way to do this is documented here which is probably the method you are already using: https://www.sierrachart.com/index.php?page=doc/StudyPriceOverlayStudy.php#OverlayStudyDiffSessionTimes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
