Date/Time: Wed, 12 Feb 2025 07:12:15 +0000
Lost connection
View Count: 466
[2020-10-14 11:18:24]
Deucalion - Posts: 31
3x times this morning lost connection to denali, while CQG on 2 platforms has been rock solid. log attched. running version 2144 with ES
[2020-10-14 11:31:11]
Sierra_Chart Engineering - Posts: 18392
The log you provided shows no disconnections.
We want you to update Sierra Chart to the latest version following these instructions to take advantage of data feed compression:
And it is also important that you run Sierra Chart in Safe Mode for now:
Sierra Chart - Software Login Instructions: Using Safe Mode
Date Time Of Last Edit: 2020-10-14 11:31:44
[2020-10-14 11:41:12]
Okay its done it again...please see pic
attachmentNew Text Document.txt - Attached On 2020-10-14 11:40:14 UTC - Size: 16.05 KB - 387 views
image2020-10-14_7-38-37.png / V - Attached On 2020-10-14 11:40:32 UTC - Size: 132.07 KB - 170 views
[2020-10-14 11:49:52]
You have some kind of connectivity or performance issue on your side to encounter this kind of condition:
SC Data - All Services | There has been no activity on the network socket for 40 seconds. Will reconnect. | 2020-10-14 07:37:16.289
The problem is not the particular version you are running but we do want you to update to the current version as we explained above. Do that to start with. This is mandatory before asking us further questions.
Date Time Of Last Edit: 2020-10-14 11:50:08
