Date/Time: Thu, 10 Sep 2026 09:20:00 +0000
[User Discussion] - ZigZag with count
View Count: 1108
[2020-10-14 09:24:03]
nicktrader - Posts: 811
Concerning "ZigZag" is it possible to add the option "with count". NT offers these option with the drawing object "Path" (see pic).
Many thanks
Date Time Of Last Edit: 2020-10-14 09:24:55
imagePath with count.png / V - Attached On 2020-10-14 09:21:45 UTC - Size: 509.95 KB - 455 views
[2020-10-14 11:07:34]
Ackin - Posts: 1865
Double ZigZag
+1
[2020-10-17 18:47:15]
Ackin - Posts: 1865
nicktrader)
Marked as [User Discussion]
So do we create it yourself? :) Could you send me more pictures of how it behaves in the range?
[2020-10-22 02:45:11]
@Ackin
I don't know what you mean by "...behaves in the range"
ZigZag is a drawing tool and as long as you draw lines, every new direction is counted up.
Date Time Of Last Edit: 2020-10-22 02:45:46
[2020-10-22 15:49:01]
Ackin - Posts: 1865
ok, I'll try to create something ...
[2020-11-01 09:20:51]
Ackin - Posts: 1865
nicktrader)
It's done... I'll do tests that everything is fine and then include it in the update... (a few days)
[2020-12-05 10:00:15]
@Ackin
Just asking. I am running 2206 and ZigZag Tool do not support "count option". Is that correct or could I just not find it?
Many thanks
[2020-12-25 09:59:51]
@Ackin
I am running now 2213 and I can't find it. Is it a new tool or modified zigzag or...
Many thanks and Happy XMas
[2020-12-25 12:57:27]
Ackin - Posts: 1865
"modified zigzag"
It was in an update before version 2194 then I removed it from the library. It is necessary to change the count there in the opposite trend. I will return it again in one of the next updates, including a description of how to use it. I'll give you information then that it's there.
