Date/Time: Wed, 12 Feb 2025 06:51:09 +0000
Replay Feature
View Count: 581
[2020-10-14 07:58:14]
User670350 - Posts: 19
I filed the info to start my Replay feature but I can't click on that because it is not highlighted?
What should I do?
Thank you;
Andrew
imageReplay 1.png / V - Attached On 2020-10-14 07:55:11 UTC - Size: 270.42 KB - 198 views
imageReplay 2.png / V - Attached On 2020-10-14 07:55:16 UTC - Size: 124.32 KB - 184 views
[2020-10-14 08:45:49]
Ackin - Posts: 1865
First you have to have an open chartbook / Chart with the same symbol (the program does not know what you want to replay from all symbols). Then you can use other functions and items in the program menu.
[2020-10-14 08:47:21]
Ackin - Posts: 1865
Basic Chart Replay Instructions
Replaying Charts: Basic Chart Replay Instructions
[2020-10-14 11:42:44]
Follow the instructions here:
