Date/Time: Wed, 12 Feb 2025 06:58:39 +0000
Question about data feed and Interactive broker
View Count: 398
[2020-10-14 02:38:53] |
GravisHTG - Posts: 306 |
I was not able to manage to make level 2 happen on my sierra chart with the feed from IB so i cancel the project. Now , i want to know if you offer Data feed for Us stock and options with level 2. thanks |
[2020-10-14 11:55:51] |
We do have a good data feed for US Equities but currently it does not provide level 2 data. Let us know if you want to proceed with it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-10-14 11:55:59
[2020-10-14 12:49:16] |
I really want to use level 2 , I will check for an alternative for now. Thanks you |
