Date/Time: Wed, 12 Feb 2025 07:06:28 +0000
Sierra Charts wont open
View Count: 632
[2020-10-13 19:23:03]
User350433 - Posts: 6
Cannot get Sierra Charts to open/run.
Purchased the $36 pkg so I can see TPO charts.
I have downloaded (I think) but cannot get the software to open.
I have a Sierra desktop icon so I think it has downloaded buit will not open.
I have attempted to disable all firewalls/
Message says " May Harm Computer" but I tell it to proceed anyway..but nothing happens.
Been working on this for days now.. need help to get going please.
Using a 5 yr old Dell Desktop w Pentium, CPO 3.4Ghz, 4 Gigs RAM, windows 10.
Thanks.
[2020-10-13 19:41:40]
John - SC Support - Posts: 37891
Is your Windows operating system 64 bit?
The most recent versions of Sierra Chart do not include a 32-bit application any longer. So if you do not have a 64-bit computer then Sierra Chart will not run.
You will need to use an older version of Sierra Chart which is explained here:
Software Download: Software Rollback Procedure
You will need to run a version earlier than 2177.
Date Time Of Last Edit: 2020-10-13 20:20:16
