Date/Time: Wed, 12 Feb 2025 06:57:27 +0000
trial extension
View Count: 424
[2020-10-13 18:36:58] |
User933112 - Posts: 2 |
Good evening, Im passing some online courses which is based on Sierra chart for trading. I have been using mt4 before and getting to know all features on Sierra takes longer time for me as Im not even half through my course. Would it be possible to get an extension for my trial account please? As I need more time to learn the Sierra and its features and implementation of trading strategies. Thank you |
[2020-10-13 20:56:07] |
Your account has been activated and the usage time extended if necessary. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
