Date/Time: Wed, 12 Feb 2025 06:48:22 +0000
Auto Projections off of H/L extended
View Count: 493
[2020-10-13 18:33:13]
Dt111111 - Posts: 5
I am trying to get auto projections to build off of a specified High/Low for Time Period study. The time period is going to be globex, and the projections should reference and create projections off of the low for downside and high for upside. I have gotten it to work using the Daily OHLC study, but I can't reference globex as specifically as I would like. However, I cannot get the projection to properly reference the high low study. It appears it wants to only reference the high or low and not use the difference between them and then project off the high or low.
Private File
Private File
[2020-10-13 19:05:00]
John - SC Support - Posts: 37891
Refer to the information here for how to use the Auto Retracement/Projection based on another study:
Auto Retracement/Projection: Basing Auto Retracement/Projection on Another Study
